Im trying to edit a figure line using the Survey Figure Properties after importing points from a file, the thing is, no points show up to be edited in the Survey Figure Properties dialog at the bottom, i tried re-importing with into a network, no dice. Seems like im just missing a check box somewhere, the points are in the file, i just cant edit the figures!
Solved by Cadguru42. Go to Solution.
If you are using 2013 you have to download the fix for that. Then, you have to click on a mysterious button (that has nothing in the help files explaining) to convert from a vector based figure (which every object in Autocad already is) to a chain based one. Then you can see the figure nodes. Why this was even added, who knows? I can't see a reason for it other than to make a change for the sake of change and say they did something in this release.
Sigh, Autode$k fails again. Thanks for the info got the patch and it worked, i didnt have to click the convert button though ,its working now....
Thanks!
