Hi everybody,
How can I determinate the volume between two surfaces ( both generated by a clouds of points)?
May I generate a corridor or directly by the interferencce?
Thank U.
Daniel
Solved by Jay_B. Go to Solution.
Depending on the version of Civil 3D you're using, the _AeccVolumesDashboard command works well for comparing a base surface and comparison surface . The command will create a Tin Volume Surface of the two.
Yes the _AeccVolumesDashboard command was a new feature in 2013 version. In 2012 it was available as subscription add on.
It can be found on the Ribbon on Analyze Tab > Volumes and Materials Panel.
