Civil 3D Forum
Earthwork Quantity
3 REPLIES 3
damacylo
252 Views, 3 Replies
Earthwork Quantity
Hi everybody,
How can I determinate the volume between two surfaces ( both generated by a clouds of points)?
May I generate a corridor or directly by the interferencce?
Thank U.
Daniel
Daniel Avila
Hydraulic Eng.
3 REPLIES 3
Jay_B
in reply to: damacylo
Depending on the version of Civil 3D you're using, the _AeccVolumesDashboard command works well for comparing a base surface and comparison surface . The command will create a Tin Volume Surface of the two.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
damacylo
in reply to: Jay_B
I use both versions: 2013 & 2014.
It is the same way to do that (volumes)?
Daniel Avila
Hydraulic Eng.
Jay_B
Yes the _AeccVolumesDashboard command was a new feature in 2013 version. In 2012 it was available as subscription add on.
It can be found on the Ribbon on Analyze Tab > Volumes and Materials Panel.
C3D 2018.1
C3D 2016 SP4
Rail Community
