Civil 3D Forum
earthwork quantities excep at bridge?
10 REPLIES 10
Message 1 of 11
1727 Views, 10 Replies
there's some old posts on this topic but thought I'd check in for latest
using C3D 2011
how to except out earthwork vic bridge?
thx,
10 REPLIES 10
Message 2 of 11
neilyj666
new corridor regions before, at and after the bridge. apply null assembly at the bridge
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 11
in reply to: neilyj666
thanks,
by "null" assembly, you just mean use no assembly at all?  in other words, just leave an unassigned gap in the corridor definition stationing?
Message 4 of 11
neilyj666
yes create an assembly with no subs and use that
Message 5 of 11
yeah, good, thanks! I'm also going to try it with an assembly with no daylight links and see what I get
Message 6 of 11
sboon
This method may not work as expected.  Keep in mind that end area volume calculations make no consideration for what is happening between the sample line stations.  If you have a sample line at one end of the bridge and another one at the other end there will be a volume calculated between them, even though the surface does not exist in that gap.  The secondary  problem you will run into is that the TIN for your corridor surface will fill in the gaps between regions unless you use hide boundaries to enforce the breaks in the surface.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 7 of 11
in reply to: sboon
much obliged,
then what strategy would you use to except out a bridge area instead?
how do you hide boundaries?
Message 8 of 11
fcernst
Civil 3d has already provided functionality for non-contiguous Material calculations such as the bridge gap scenario, and pockets of Materials.
The correct procedure to do this is to Gaps when you compute your Material Volumes:
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 9 of 11
in reply to: fcernst
that works great, the trick is to have sample lines set at the begin and end of the exception area
thank you
Message 10 of 11
sboon
There are a couple of options for this issue
The corridor used for this road surface includes an assembly across the bridge with two horizontal links 1mm wide.  Those links have Top link codes and Daylight point codes so that the corridor surface is continuous across the bridge and its boundary is dynamic.
In the volume table the last full section at the north abutment is at 27+63.10  There is another sample line at 27+63.30 where there is no fill and very little volume.  Across the span there is negligible volume accumulated until you get to the south abutment at 28+42.75
In this version I've left a gap between corridor regions.  The surface has been allowed to interpolate across the bridge.  I've deleted the sample lines between the abutments and applied a gap to the Material volume calculations as Fred suggested earlier.  This method simplifies the process of doing the calcs and provides a more accurate result but the interpolated surface across the bridge can be an issue if you want to display finished contours or sections.  The placement of the sample lines at the abutments and the gap stations are not dynamic so you need to update if the corridor changes.
Steve
Steve
Message 11 of 11
in reply to: sboon
thanks very much, very useful example!  much obliged
Rail Community
