i am working with C3D 2014, and the co-worker who is working at another office has C3D 2012. When i saved down to 2010 version, he doesn't see anything? Is there anyway he can see my designs with his version 2012?
Thank you,
Dennis
Solved by odoshi. Go to Solution.
You would have to use the Export to AutoCAD 2010 command, found in the application menu. This will "dumb down" the Civil 2014 objects to just blocks.
Unfortunately, Civil 3D objects are versioned every year. The only cross compatibility is now between versions 2013 - 2015.
Mike
