New Member
uwotmate
Message 1 of 5 (1,626 Views)
Dynamic Scale Bar Question..
1626 Views, 4 Replies
10-03-2012 06:50 PM
I've used the search key and found multiple topics on scale bars but nothing that answered my question directly.
How do I insert a dynamic scale bar?
I'm trying to insert a scale bar into a paper space (I use layout wizard and make a layout). Then once I'm in the layout that I've created I see a button that says Scale Bar > and I have several to choose from; cool. I select the one I want to put in the drawing, and command bar asks me "Select viewport" ?? How do I select 'viewport'? Everywhere I click, it says 'Nothing selected'. I want it in there at 1:250 (the scale of my model space drawing, and the scale of the 'viewport' that I selected during the layoutwizard process.
Would really appreciate any help with this.
I also tried inserting one of the sample scale bar blocks (which are at 1:1 scale) and then scaled it up to 250, but it looks way to small for my drawing.
You are doing everything I do to get the scale bars.
Click the Scale Bar drop down
Select a scale bar to use
Click on the border of a viewport
A dialogue comes up to enter the scale, label, divisions
Click OK button
Pick Point to insert the scale bar
I have tried it with a rectangular viewport and a polygonal viewport, viewports locked and unlocked, also with the current layer off and locked, and it still works alright, although with the layer locked, you don't get the scale bar after you pick it's insert point.
Turning the viewport layer off or freezing it makes it not visible so you can't pick it anyway.
Sorry, but I could not find a way to get it not to work.
You probably need to select the entity representing the outline of the viewport. That's the viewport object itself. You need to be in paperspace and the layer that the viewport was created in needs to be on, thawed and possibly unlocked. I don't use the layoutwizard of dynamic scalebars. So this is just extrapolation from other instances where you have to select a viewport.
Allen
Distinguished Mentor
andrewpuller3811
Message 2 of 5 (1,614 Views)
Re: Dynamic Scale Bar Question..
10-03-2012 09:03 PM in reply to: uwotmate
Click OK button
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
AllenJessup
Message 3 of 5 (1,591 Views)
10-04-2012 05:11 AM in reply to: uwotmate
Allen
Active Contributor
Pollmuller
Message 4 of 5 (1,384 Views)
01-11-2013 04:31 PM in reply to: andrewpuller3811
Can I ask you what version of CAD you are using? I'm using CAD Civil3D 2012 and I can't find the "Scale Bar" drop down menu. I've tried typing it in the command line but that brought up nothing.
AUTOCAD Civil 3D 2013
Windows 7
Processor: Intel (R) Xeon (R) CPU W3565 @ 3.20GHz
Installed Memory (RAM): 12.0GB
System Type: 64-bit
Erika
neilyj
Message 5 of 5 (1,370 Views)
01-12-2013 12:28 AM in reply to: uwotmate
i think it first appeared in 2013
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
