Civil 3D Forum
Dynamic Scale Bar Question..
5 REPLIES 5
4447 Views, 5 Replies
I've used the search key and found multiple topics on scale bars but nothing that answered my question directly.
How do I insert a dynamic scale bar?
I'm trying to insert a scale bar into a paper space (I use layout wizard and make a layout). Then once I'm in the layout that I've created I see a button that says Scale Bar > and I have several to choose from; cool. I select the one I want to put in the drawing, and command bar asks me "Select viewport" ?? How do I select 'viewport'? Everywhere I click, it says 'Nothing selected'. I want it in there at 1:250 (the scale of my model space drawing, and the scale of the 'viewport' that I selected during the layoutwizard process.
Would really appreciate any help with this.
I also tried inserting one of the sample scale bar blocks (which are at 1:1 scale) and then scaled it up to 250, but it looks way to small for my drawing.
5 REPLIES 5
andrewpuller3811
You are doing everything I do to get the scale bars.
Click the Scale Bar drop down
Select a scale bar to use
Click on the border of a viewport
A dialogue comes up to enter the scale, label, divisions
Click OK button
Pick Point to insert the scale bar
I have tried it with a rectangular viewport and a polygonal viewport, viewports locked and unlocked, also with the current layer off and locked, and it still works alright, although with the layer locked, you don't get the scale bar after you pick it's insert point.
Turning the viewport layer off or freezing it makes it not visible so you can't pick it anyway.
Sorry, but I could not find a way to get it not to work.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
AllenJessup
You probably need to select the entity representing the outline of the viewport. That's the viewport object itself. You need to be in paperspace and the layer that the viewport was created in needs to be on, thawed and possibly unlocked. I don't use the layoutwizard of dynamic scalebars. So this is just extrapolation from other instances where you have to select a viewport.
Allen
Allen Jessup
CAD Manager - Designer
in reply to: andrewpuller3811
Can I ask you what version of CAD you are using? I'm using CAD Civil3D 2012 and I can't find the "Scale Bar" drop down menu. I've tried typing it in the command line but that brought up nothing.
neilyj666
i think it first appeared in 2013
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
TiStars
Same problem appeared to me, C3D 2016.  anywhere i clicked doesn't work, keep saying "Nothing selected"
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Rail Community
