Civil 3D Forum
Dynamic Scale Bar in 2013
21 REPLIES 21
Message 1 of 22
29815 Views, 21 Replies
I recently discovered the "Scale Bar" function located in the Layout Tools tab on the Ribbon. With this tool, you can insert a dynmaic scale bar, link it to a viewport, and have it adjust as you adjust the viewport scale. The problem I'm having is getting the text below the scale bar to read like I want.
The scale bar I'm using is "Scale Bar 4 Imperial." Currently the text below the scale bar (which is the scale ratio) reads: 1:600 (see attached image). While this ratio is correct (1 inch in paper space = 600 inches in model space), I do not want this displayed. I would like to have 1" = 50' displayed below the scale bar. Does anyone know how to modifiy the dynamic block so that this can be achieved?
Thanks!
21 REPLIES 21
Message 2 of 22
ToddRogers-WPM
Yeah, the scale bar seems to use a factor of 12, so if you have a drawing of 1"=20', then it will show 240.  This is completely STUPID.  Not sure why this was designed this way.  You can use mine that I have attached.  It's a dynamic block.
Todd Rogers
Message 3 of 22
Can I use this block in the "Scale Bar" menu? The text in your block doesn't look dynamic, unless I'm missing something.
Message 4 of 22
ToddRogers-WPM
It's not dynamic to the viewport, but it IS a dynamic block. If you click on it, then you will get a triangle grip which holds all the variations of scales. Todd Rogers, A.E./P.S.E. [cid:image001.gif@01CD65BD.1B676E40] [cid:image002.jpg@01CD65BD.1B676E40] www.tcadsys.com480 N. Sam Houston Pkwy. E. Suite 234 Houston, TX 77060 P: 281.445.6161 F: 281.445.5999 Check out some of my videos on Total CAD's blog site... Design Detention PondCheck out Total CAD Systems' blog site at http://totalcad.wordpress.com/ Check out my blog site at http://civil3dj.wordpress.com
Todd Rogers
Message 5 of 22
andrewpuller3811
IF you look here : -
C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\Sample\Symbols
You will find the file - "Map - Scale Bars.dwg" which is the file civil 3d looks to to get the scale bar blocks.
In the help, check out the "To create a custom scale bar" topic in the"AutoCAD Map 3D User Help > Visualization and Styling > Working With Display Maps > Adding a Scale Bar" Section.
There is also a file "Map - North Arrows.dwg" that is used for the north arrows.
If you are going to edit these files, make sure you create a back up of the files first.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 6 of 22
in reply to: andrewpuller3811
Yes, I've tried to edit the Scale Bars blocks, but I can't seem to figure out how to modifiy the text below the scale so that it dynamically updates and reads the drawing scale (1"=50', for example).
Message 7 of 22
andrewpuller3811
Only thing I can see is once the scale bar is in the drawing, select it and in the properties pallete, you can change the value of the Map.ScaleBar.ScaleRatio attribute to 1":50'. This will only last until the scale of the viewport is updated, then it will be set to 1:300 or whatever the new scale is.
Andrew Puller
Civil 3d 2021
Message 8 of 22
a workaround for this is to use one of the build in scale bars without the scale label then use an mtext, insert a field, in field category select Objects, click icon to select the viewport, select from the property list Custom scale and the desired format, then it will update if the viewport scale changes but need to do regen.
Message 9 of 22
JamaL9722060
That’s really very frustrating that the built-in scale bar is not “annotative” and thus its text don’t not change proportionally to the selected scale of the viewport (attached)!
Best
Jamal
Jamal Numan
Message 10 of 22
Jfactory
If you had your units in feet and things scaled to feet, your drawing unit of 1 would be 1 foot. Then the scale would work nicely as 1:50
Otherwise you can double-click to open attribute editor and you can manually change it.
Sorry for bumping this old thread but I was having issues and I found this thread and thought I'd offer what I learned.
Message 11 of 22
in reply to: Jfactory
I set the units to feet and still shows the scale factor multiplied by 12,
the viewport scale is 1"=100' and the scale bar shows 1:1,200
[cid:image001.jpg@01CE6786.CDD4D880]
Message 12 of 22
BrianHailey
Insert the block, redefine it so the attributes are no longer using the "special" attribute name Map is looking for. Sync your block using the Block Attribute Manager (BATTMAN). Put a field into that attribute that returns the viewports scale name.
If this is something you will use a lot, go edit the blocks in the drawing listed in a previous post and then you won't have to redefine the block when you insert it (you'll still need to add the field though).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 13 of 22
jmayo-EE
The bar is scaled by 12 in paperspace? Can you use CHSPACE and just let it go to model space?
John Mayo
Message 14 of 22
jmayo-EE
in reply to: jmayo-EE
I'll answer myself, no...
John Mayo
Message 15 of 22
LyleHardin
Ours works quite nicely. It's out of the box. There are occasionally issues with decimals showing up. Here are the settings. This one does happen to be messed up (see the custom fields), but right now I'm in plain AutoCAD and cannot do anything about it.
Here is a screen cast showing how to fix the decimal problems I occasionally have.
https://knowledge.autodesk.com/community/screencast/60045c9b-3495-41b4-8251-386a676d58a5
Message 16 of 22
Joe-Bouza
Not trying to poo poo your new found tool but be prepared for some issues with your vport loosing the view if you are using civil3d in these vports.
I can't quote any known issue document but I'm fairly sure that they do cause problems with c3d files. Plan production sheets in particular
Joe Bouza
Message 17 of 22
LyleHardin
in reply to: Joe-Bouza
Not really so "new found". We've been using this for a few years and have not noticed anything getting corrupt or missing. At least not that anyone has told me about.
We've just some issues with the scale bar itself. Thanks for the heads up though. We'll keep that in mind when things go wonky as they do now and then with C3D.
Message 18 of 22
Dear Sir,
   I would like to know how to create the scale bars in metres, please show me the procedure or video it will be appreciated
thanks and regards
Message 19 of 22
I am trying to watch your screen cast but when trying to enlarge the view it does not allow me and it to small. Can you redo the screen cast to make it larger.
Windows 10 Professional Pro
Intel(R) Core(TM) i7-6700 CPU @ 3.4 3.41 GHZ
16 GB
64-bit Operating System x64-based processor
AutoCAD Civil 3d 2016 sp 4
Message 20 of 22
I am currently using civil 3d 2012 and still learning about this dynamic scale bar block. When I d/l your file I get a message scale_block.dwg contains authoring elements. Open block editor. yes no cancel. I next click yes and I do see the triangle but where do I go from here?.
Can you explan to me how can I get this to work.
16 GB
Rail Community
