Mark Green
Working on Civil 3D in Canada
Mark Green
Is the horizontal position staying in the same location and just the elevation changes per the road way?
And will the targeted feature line have one elevation for the entire length? If not, what determines the elevation of the pad?
Don Ireland
Engineering Design Technician
Hi Doni I have attached a screen shot of an old draft showing the pads in yellow. At the moment there is no way to control the elevation of the pads without labling the corridor with a spot elevation and then applying that elevation as the elevation of the polyline/breakline.
Yes you can.
I can post the sample file because it is too big.
0.1 make your corridor surface
0.2 make FG surf and paste corridor srf into it
1. Make all your pads alignments
2. Extract dynamic FL from the back of sidewalk and place in a site called TEMP
Create gradings off the BOSW the length of corridor defining slopes, hinges etc. Do this ignoring the geometry. Specifically grade beyond the back of pads. Ignore daylight at this point. Have the gradings make an auto srf called something like TEMP.
4. Create surface profiles for all pad alignments using TEMP
5. Create dynamic FL from alignments choosing each pad (make sure they DO NOT go into site TEMP)
Add dynamic pad FL to FG
7. Create two perimeter alignments around the back and sides of the pads on both sides of the street side called perimeter1 and perimeter 2 (be sure they are covered by surface TEMP and create surface profiles for each using TEMP
8. Create dynamic FL from the two perimeter alignments into SitePerimeter
9. Create daylight grading off the two perimeter FL daylight to EG (DO not create a surface from these gradings)
10. Add perimeter FL and daylight FL to FG.
Now if you adjust you corridor profile all the lots and daylighting will react accordingly
Joe Bouza
Mark Green
Forecast is Sunny
simply change the grading scheme to grade to elevation across the lots and insert transition between
cant find a criterior to grade by dist to elevation regardless of slope. Why wouldnt you follow the corridor?
Joe Bouza
Mark Green
<snip>
Not really dynamic, but probably better that what you have?
That's cold dude
Joe Bouza
Mark Green
Joe Bouza
