AutoCAD Civil 3D General Discussion
Valued Contributor
DrWileFTracer
Message 1 of 9 (252 Views)
dynamic block issue
252 Views, 8 Replies
07-10-2012 05:47 AM
I made a simple block for a utility pole in plan view. It consisted of a donut with one string of mtext beside it. I had  created it so that the text would orientate itself to be horizontal in each viewport regardless of the ucs angle. I later added a line for a guy wire and made the block dynamic with visibility states. Now I am unable to have the text orientate to a horizontal position in the viewports. Any ideas?
Wil
*Expert Elite*
tcorey
Message 2 of 9 (237 Views)
Re: dynamic block issue
07-10-2012 11:19 AM in reply to: DrWileFTracer
Edit the block, delete the existing text, add it again.Does that help?
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Valued Contributor
DrWileFTracer
Message 3 of 9 (208 Views)
07-17-2012 05:55 AM in reply to: DrWileFTracer
Unfortunately that doesn't work.
Wil
Valued Contributor
DrWileFTracer
Message 4 of 9 (202 Views)
07-17-2012 06:59 AM in reply to: DrWileFTracer
Sorry for the late response, but no it doesn't work. Worth a try though. Thanks Wilf Carter Senior Designer [cid:image001.png@01CD640B.1EFDCDA0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
*Expert Elite*
Joe-Bouza
Message 5 of 9 (201 Views)
07-17-2012 07:27 AM in reply to: DrWileFTracer
Is the text a block attribute or imbedded mtext in the block? Mtext in the block works on my end, but attributes will not
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Valued Contributor
DrWileFTracer
Message 6 of 9 (193 Views)
07-17-2012 10:42 AM in reply to: DrWileFTracer
mtext Wilf Carter Senior Designer [cid:image001.png@01CD642A.4D091FA0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
*Expert Elite*
Joe-Bouza
Message 7 of 9 (187 Views)
07-17-2012 12:30 PM in reply to: DrWileFTracer
Gee I put Mtext in a block and it worked. Are you sure you checked the visual fidelity box for the style to orient to the view? Can you post the block?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Contributor
DrWileFTracer
Message 8 of 9 (170 Views)
07-18-2012 05:11 AM in reply to: DrWileFTracer
The box is checked. I've tried using text, mtext and attributes. I've tried making the text associative, I tried making it not associative. I tried clicking both "yes" and "no" to "match orientation to layout". When I insert it into a file containing all my other dynamic blocks and go into the block editor, I've tried clicking both "yes" and "no" to "associative. When I try to pick "yes" for "match orientation to layout", it immediately defaults back to "no". I've tried as many combinations of text types and settings as I can think of and nothing works - and I can't stop the "match orientation to layout" to defaulting back to no". Wilf Carter Senior Designer [cid:image001.png@01CD64C4.FDA3A3E0] 102 Portland Street Dartmouth, Nova Scotia Canada B2Y 1H8 www.ablenvironmental.comPh: 902-466-0050 Ext: 111 Fax: 902-469-4399 wcarter@ablenvironmental.com
Product Support
Volker_C
Message 9 of 9 (156 Views)
07-19-2012 09:24 AM in reply to: DrWileFTracer
Can you post the block so that we can examine it?
Thanks!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker Cocco
Support Specialist
Product Support
Autodesk, Inc.
Post to the Community
New Post
Need installation help?
