I made a simple block for a utility pole in plan view. It consisted of a donut with one string of mtext beside it. I had created it so that the text would orientate itself to be horizontal in each viewport regardless of the ucs angle. I later added a line for a guy wire and made the block dynamic with visibility states. Now I am unable to have the text orientate to a horizontal position in the viewports. Any ideas?
Wil
Edit the block, delete the existing text, add it again.Does that help?
Tim
Is the text a block attribute or imbedded mtext in the block? Mtext in the block works on my end, but attributes will not
Your Name
Gee I put Mtext in a block and it worked. Are you sure you checked the visual fidelity box for the style to orient to the view? Can you post the block?
Your Name
Can you post the block so that we can examine it?
Thanks!
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
