Member
Miguel7799
Message 1 of 4 (235 Views)
dwg topography to 3d solid
235 Views, 3 Replies
11-13-2012 04:04 AM
Hi. I need to create a 3d terrain solid from dwg nivel curves (contours). I tried with loft command but the lines are too detailed and my pc takes a eternity to loft just 2 lines and i have a lot of it.
I was wondering if use revit will be a good option. Can you please tell me the best way to do it and dont create a extensive 3d file?
Regards
antoniovinci
Message 2 of 4 (226 Views)
Start from here, sir.
11-13-2012 05:28 AM in reply to: Miguel7799
*Pro
dgordon
Message 3 of 4 (165 Views)
Re: Start from here, sir.
11-29-2012 10:39 AM in reply to: antoniovinci
before he can use that advice he has to first create a C3D surface from the contours.
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
tcorey
Message 4 of 4 (161 Views)
Re: dwg topography to 3d solid
11-29-2012 10:48 AM in reply to: Miguel7799
Are you using Civil 3D? If so, do as the previous poster suggested and create a Civil 3D surface from your contours and then follow AntonioVinci's link.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
