Civil 3D Forum
DWG to PDF with layers
10 REPLIES 10
Message 1 of 11
trynders
561 Views, 10 Replies
Running C3D 2012.  I have a page set up of DWG to PDF.  I have went into the properties of the DWG to PDF.pc3 and told it NOT to include layers.  If I publish just the one drawing, all works good, no layers.  If I add addition sheets, or even just one more, for a total of two drawings, I get layers in the PDF.  Even both times in the publish option, I have selected dont include layer infomation.
Any thoughts?
10 REPLIES 10
Message 2 of 11
kcobabe
in reply to: trynders
How are you publishing.  If you do a publish from the sheet set manager I belive the driver for that still will print layers.  In order to get it to not do that you have to print to the pc3 driver.
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 3 of 11
trynders
I create a page set up in my first drawing (or File).  click on Publish and add the remaining drawing to complete the set.  Highlight all sheets in the publish window and select the page set up from the first file.  And off it goes...
Message 4 of 11
IanMcClain
Publish has it's own options that may be over-ridding the .pc3.  Look for a Publish Options button in the upper right hand sided of the publish window; there is an option for layer information.
Ian McClain
Message 5 of 11
kcobabe
Did you click on the publish options and turn off the layer inculsion?  Publish Options->General DWF/PDF Options->Layer Information
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 6 of 11
trynders
I am aware of that also.  I changed the properties of my device under "custom properties" to not include layers and in the publish box to also not include layers.  I must have a corrupt file some where.  I did just delete my dwg to pdf.pc3 file and created a new one but no change in results.
Message 7 of 11
kcobabe
You are looking in the wrong place.  This is not in your page setup or print dialog.  This one is in your publish dialog.  There is a button that you change the option to not include layers.
Type in help browser "Publish Options" and it should be the first hint.
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 8 of 11
trynders
I am aware of the layer information box in the publish options.  I have it NOT check and am still getting layers.  See attachment
Message 9 of 11
kcobabe
Do you leave your page setup on "None" or do you switch it after?
When you switch does it change the publish options then?
R10 - 2020 ACAD
2014 - 2020 Revit
Infraworks
2018-2020 Inventor
2020 Navisworks
Message 10 of 11
trynders
As stated in my second post.  No. Publish layers never changes...  This has me good...
Message 11 of 11
IanMcClain
There is another location for the same setting under the Sheet Set Publish Options.
Are you using a sheet set? Even if you are not you may want to check this location for the same setting and ensure that layer information is set to don't include.
From the AutoCAD 2010-2012 forum: http://forums.autodesk.com/t5/AutoCAD-2010-2011-2012/Problem-Publish-using-Page-Setup-Override/m-p/3...
Ian McClain
Rail Community
