Hello there!!!
Is there any autodesk software converter to convert from dwg file to pdf file?
or if there is any simple way you can tell me to convert dwg file to word document?
Shiny
Solved by ToddRogers-WPM. Go to Solution.
You have to print it to a PDF. There is a print driver for this included in the software. If you go to the print dialog box and choose the printer DWG to PDF, you will be prompted for a place to save the pdf file.
When I go to Print, there is no option for DWG to PDF, where is it and how do I get it?
Mark Green
Working on Civil 3D in Canada
Mark Green
