Civil 3D Forum
DWG to PDF converter
5 REPLIES 5
1356 Views, 5 Replies
Hello there!!!
Is there any autodesk software converter to convert from dwg file to pdf file?
or if there is any simple way you can tell me to convert dwg file to word document?
Shiny
5 REPLIES 5
ToddRogers-WPM
You have to print it to a PDF.  There is a print driver for this included in the software.  If you go to the print dialog box and choose the printer DWG to PDF, you will be prompted for a place to save the pdf file.
Todd Rogers
in reply to: ToddRogers-WPM
When I go to Print, there is no option for DWG to PDF, where is it and how do I get it?
troma
What version are you running?
Another option is to download the free 'Cute pdf' software that also acts like a print driver in the same fashion.
Mark Green
Working on Civil 3D in Canada
in reply to: troma
I'm running Auto CAD 2013 LT. I just got it and there is no pre-set printer driver at all. Is that because it's LT?
I was able to download a PDF Writer for MAC from Lisanet, it works as a printer, but the drawings do not print to scale. This was the only download I was able to find that was MAC compatible.
I managed a work around by using that as the print manager but doing a save as Adobe PDF. That did print to scale, but that means I would have to buy Adobe just to do a save as.
I will look into the "Cute PDF" you mentioned, but I'd still like to know if I should have a built-in PDF writer for CAD.
Thanks so much
Leana Porter
troma
I'm guessing you got here from some web search, coz you got blown way off course!
Here is the area for questions about LT:
http://forums.autodesk.com/t5/AutoCAD-LT/bd-p/43
Here is the area for questions about AutoCAD for MAC:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
Here is the area for questions about printing and plotting:
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
This spot right here where you posted is about Civil 3D, which is built on top of Map, which is built on top of AutoCAD full version, and is not available on MAC.
Mark Green
Rail Community
