Civil 3D Forum
DTM & ALG Files
5 REPLIES 5
sswanson
9406 Views, 5 Replies
DTM & ALG Files
We have a job coming up where our client plans on sending us  .dtm  & .alg files to create a surface model using C3D 2013.
I am not sure what these files are but I  believe they maybe Micro Station or Inroad files.
My question is how do you use these in C3D 2013? Do I convert or import them , and if so how?
Or is there a better formant  more  compatible with C3D, that I should request from our clients?
                                               Thank You
                                                    Steve Swanson
5 REPLIES 5
wfberry
in reply to: sswanson
Without knowing anything about the .alg file and the dtm file is probably different as well.  Hopefully they can send you a LandXML file (for the surface) which should be "non-denominational" and have the surface already built.
Bill
Lisa_Pohlmeyer
Steve .alg files belong to InRoads. That application has the ability to export to LandXML. As Bill said, if they export, you can import the surface as they intended it to be, keeping the liability (responsibility for it's creation) with them. Here's a good workflow provided by Wisconsin DOT. http://www.wsdot.wa.gov/publications/fulltext/design/cae/TechNotes/IR-GeometrytoLandXML.pdf Although the workflow isn't for surfaces, I've received them in the past.
Lisa Pohlmeyer
Civil 3D User
Website | Facebook | Twitter
Tags (2)
Neilw_05
The DTM file is an Inroads surface model file. Unless there is a utility available somewhere you won't be able to use it as it is a proprietary format.
The ALG file is an Inroads alignment database.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
sswanson
in reply to: Neilw_05
Thanks to all of you for your help. Our client will be sending us a
LandXML file.
Thanks again
Steve Swanson
esepolen
in reply to: Lisa_Pohlmeyer
link no longer works
Rail Community
