Civil 3D Forum
DS project description
15 REPLIES 15
Message 1 of 16
Joe-Bouza
357 Views, 15 Replies
Is there a way to add descriptions to DS project folders after the fact?
Your Name
Your Name
15 REPLIES 15
Message 2 of 16
Jeff_M
in reply to: Joe-Bouza
Yes, but you will need to edit the "ShortcutsHistory.xml" file for the project.
Edit: I removed the description of how to do this because I now can't get the description to display. I know I've done this in the past, now to figure out why the method I used isn't working.
Jeff_M, also a frequent Swamper
Message 3 of 16
wfberry
in reply to: Jeff_M
Jeff:
Perhaps you forgot the CURSE of the JOE!
Bill
Joe:  I have your back!
Message 4 of 16
Joe-Bouza
in reply to: wfberry
And the curse manifest itself upon the victim causing inexplicable misspellingSmiley Wink
Jeff, thanks for looking
Your Name
Your Name
Message 5 of 16
Jeff_M
in reply to: Jeff_M
Now I remember! Thanks to Almas @ BeingCivil for posting this today.
Message 6 of 16
jmayo-EE
Spell checkers world wide fear you.
Ohh sorry, let me translate.
spel cheker wirld wide feer u.
John Mayo
Message 7 of 16
Joe-Bouza
LOJ, Thsta funnnu
Your Name
Your Name
Message 8 of 16
DarrenP
read this: http://beingcivil.typepad.com/my_weblog/2012/06/cannot-see-data-shortcuts-descriptions.html?utm_sour...
DarrenP
Message 9 of 16
DarrenP
in reply to: DarrenP
in case any one else wants to know what blog it is
DarrenP
Message 10 of 16
jmayo-EE
Thank you Jeff, Almas, darren and Joe for posting. I will also put this to good use.
John Mayo
Message 11 of 16
Joe-Bouza
in reply to: Jeff_M
It is a very nice blog, but I am either too dense or too stupid to understand it. I do not have a shortcuthistory.xml file in the places discussed. I'm thinking it should be on the server somewhere, how else would other read it?
Your Name
Your Name
Message 12 of 16
Jeff_M
Sure you do, Joe. It is not saved to the server becuase it is a per-user cache. In the address bar of Windows Explorer, type in %APPDATA% and hit enter, it will take you to YOUR profile's Appdata roaming folder, browse down to the folder shown. It should be noted that each version of C3D keeps it's own cache as well.
Message 13 of 16
Jeff_M
Oops, now I see you said shortcuthistory.xml. This is in the actual project shortcut folder which may be on the server:
Message 14 of 16
Joe-Bouza
in reply to: Jeff_M
I searched our server for short*.xml and nothing came up?
Your Name
Your Name
Message 15 of 16
Jeff_M
Joe, when in C3D and you have a Project 'live' from which you can create Data References, what does it say next to Data Shortcuts in Prospector? The path you find there is where you need to be looking.
Message 16 of 16
Joe-Bouza
in reply to: Jeff_M
I get it now - one ShortCutHistory.xml per project.
Its really quite simple once you understand it Smiley Very Happy
Your Name
Your Name
Rail Community
