Joe-Bouza
Message 1 of 3 (111 Views)
DS oddity
111 Views, 2 Replies
12-19-2012 08:39 AM
I have a sheet drawing that that I copied from one project to another, and change the project association in the DS node of the prospector. Created new profile data and DS'd to the copied sheet. The prospector shows only the new alignments and profiles in the node.
Here is where things start getting weird: When I try to create a profile view the wizard shows the correct alignment, however the station range in the wizard shows 0+00 to 0+00? And if I just click create profile view it create an empty view 0+00 to 0+00 with an alignment name from the old project!?
There is nothing in the prospector from the old project and as I sai I associated the drawing with the new project.
Anyone see this before or know a way out?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
troma
Message 2 of 3 (103 Views)
Re: DS oddity
12-19-2012 09:01 AM in reply to: Joe-Bouza
What happens if you manually type in the required stations?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Joe-Bouza
Message 3 of 3 (93 Views)
Re: DS oddity
12-19-2012 09:29 AM in reply to: troma
t,
I'll get back to you I am needed in the field.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
