I have a sheet drawing that that I copied from one project to another, and change the project association in the DS node of the prospector. Created new profile data and DS'd to the copied sheet. The prospector shows only the new alignments and profiles in the node.
Here is where things start getting weird: When I try to create a profile view the wizard shows the correct alignment, however the station range in the wizard shows 0+00 to 0+00? And if I just click create profile view it create an empty view 0+00 to 0+00 with an alignment name from the old project!?
There is nothing in the prospector from the old project and as I sai I associated the drawing with the new project.
Anyone see this before or know a way out?
Your Name
Your Name
t,
I'll get back to you I am needed in the field.
Your Name
Your Name
