I have a AutoCAD Civil 3D 2015 and for some reasons when I make a new drawing or open existing one some of the dimensions under Drawing Settings -Ambient Setting opens in the imperial system even if I'm using C3D_Metric drawing.
I'm just looking for a way to be sure that metric drawings opens in the metric units. It mess everything up that some of it is in imperial and some in metric.
Helgi
Are you creating a new drawing? Are you specifying _AutoCAD Civil 3D (Metric) NCS.dwt as your template? Unless someone got in there and messed with your template, that should open a new drawing with all metric settings.
Or is it an existing drawing? Dog only knows where it came from and what someone might have done to it before you got it.
Which settings are metric, and which are imperial? Drawing Settings units is metric? Are you seeing imperial units in styles or in ambient settings?
Care to post?
Is your drawing template from acad or c3d?
I have found a drawings from plain acad opened in C3d will do this.
Solution, insert drawing into metric template.
(Drawings that have been exported back to acad have been known to have the same issues)
If new drawing display the same characteristics. I'd suggest checking your template. It sounds like those settings are coming from there. The only other possibility I can think of is that you have a 3rd party program or lisp that might be changing the settings. But I find the Template a much more likely source.
Allen
Allen Jessup
CAD Manager - Designer
