Civil 3D Forum
Drawing vanishes when regen is used
5 REPLIES 5
robflintoff
299 Views, 5 Replies
I have had this issue for awhile and lived with it but it is now causing issues with other users in the office. I have looked for a solution but cannot find one.
Problem: occasionally when I copy an object (text, polylines, blocks etc) and then paste, it appears as though nothing has happened. However the object is copied, it is simply not visible.  If I then regen all entities also vanish. I can save and reopen the drawing this fixes the issue. For me this is fine, but it is happening to others multiple times in one day.
Any suggestions??
5 REPLIES 5
AllenJessup
in reply to: robflintoff
The first thing I'd try is to update the video drivers to the latest version. If you have a certified card. Look [HERE].
Allen Jessup
Allen Jessup
CAD Manager - Designer
Jeff_M
Please let us know which version of C3D you are using, as well as which Service Packs, if any, have been installed.
jmayo-EE
Are you zooming to the dwg extents in the operation as well? If so you should also confirm you are holding the same coordinates through the copy/paste operation.
If you paste something into a file that is well outside the working coordinates, zooming to the file extents will make everything appear to disappear.
John Mayo
robflintoff
in reply to: AllenJessup
Thanks Allen, turns out my video driver was in need of an update. I will continue to work and see if the issue happens again.
AllenJessup
Hope that was it. That's just the first step I take when having any display problems.
Allen Jessup
Allen Jessup
Rail Community
