Is it possible to insert a "field" instruction in the drawing template to get automaticaly the stations (begining and end) of the long profile for the sheet considered ?
Example 0+700 - 1+400
MHB
that would be nice. I bet someone with vbs or .net experience could get the matchline field.
Your Name
Your Name
Thanks for this.
I have partially solved the problem by setting the names of in the viewframesgroup (toolspace > settings >> default name format) so that the layout name template gets the name of the alignment + start and end station.
But know I have a problme to solve regarding the creation of multiple viewframes with set ranges and set overlap. See my next posting.
Cheers,
MHB
That sounds elegant. How do you get it into SSM drawing name field?
Your Name
Your Name
Attached
a dwt with the fields and a raster with the settings for the viewframes and sheets in toolspace / settings
hope this helps, don't hesitate to contact me if any prob.
MHB
Hi MHB
any chance you can email me your sample? I cannot down load from the DG; our fire wall settings disallow
Your Name
Your Name
