The way to "reference" corridor information into another drawing is to xref
it in. New in 2008 you can sample corridor sections from a corridor that is
being xrefed in. Yes, that is an xref (external reference) not a data
reference or shortcut. Apparently, in order to do a data reference of a
corridor, you would have to bring in the assemblies and sub assemblies and,
well, a bunch of stuff (I wonder why a surface reference doesn't bring in
the points and breaklines and...). Autodesk decided to make this one object
available via xrefs.
Brian
http://www.ctcivil.com
http://cadcafe.blogspot.com
wrote in message news:5580704@discussion.autodesk.com...
will it work to xref in the corridor? I thought you had to use data
shortcuts to get the new file to read anything from civil 3D. Right now I
have a basemap with my alignment and profile, and another file with my
corridor, sample lines, assemblies and cross sections.
So you're saying I should have everything except the cross sections and
sample lines in the basemap?
