Afternoon
I am new to Civils 3d and have a totally structural background.
What I need to know is, will the drawing sheets/titleblocks attributes etc, I have created to insert in AutoCAD work in Civils 3d or will i need to create separate ones.
Thanks in advance
they will work nut you should look out for your INSUNITS variable. More that likely your sheet was created with units set to inches and you my get the wrongsize on insert.
Your Name
Your Name
