Civil 3D Forum
Drawing settings object layers
2 REPLIES 2
jbear0000
371 Views, 2 Replies
My company is updating our layer standards. We have many templates already created and each one will need to be updated. Changing the layer names is easy using the rename command. The only problem is that when I go to Toolspace -> Settings tab -> Right click on the drawing name -> Drawing Settings -> Object Layers tab, the layer names do not update. For example: The old layer name for Alignments was "P_ALGN", the new layer name is "O-ALGN", but the layer listed in the settings is still "P_ALGN". Sure I can update it manually, but I would need to do that for all of the object layers in all of our different templates. Is there some way to force those layers to update automatically?
2 REPLIES 2
tcorey
in reply to: jbear0000
Short answer is no, but that's not entirely true.
There is a 3rd Party software, SincPac, that will do this. Take a look at http://www.quuxsoft.com/SincpacC3D.aspx
SincPac lets you open your template, export the object layers to xml. Open the new template and import object layers. It's pretty reasonably priced.
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
jbear0000
in reply to: tcorey
I figured that. I don't think I could justify the purchase of SincPac to our software manager just to fix the layers in the templates. Thanks for the suggestion though.
Rail Community
