I want to create road cross section from excel file. I have only offset and elevation. can anyone help to me to create cross section?
Solved by wfberry. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
You could probably create cogo points at the locations specified in your spreadsheet, using the transparent commands.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Hi, I believe maqsood had a similar issue, check it out
Why not use Excel's Concatenate to draw the polylines? Start the polyline command and paste the coordinates in the command line.
This might help http://docs.autodesk.com/CIV3D/2012/ENU/filesCUG/GUID-C19507FA-54AC-430F-A41B-B0CAFA8A4D8-702.htm
Joe Bouza
In line with what Steve said, all you need is convert your information to an ASCII format (.csv). You will need to have the station numbers included on each line. Go to the search mode in Civil 3D HELP. Enter: "Creating Points on an Alignment by Importing ASCII Files".
The directions are pretty clear.
Bill
I think this is the best way to creat cs for any surface.
Hi
I produce a DLL which it can import sections from a text file and export section view to a text file.
After Loading this file (section.dll) with NETLOAD command in Civil3D, you can export your section view with "Exportsec2xyzoffsta" command. This command generate a text file with PXYZ and Station format from your section view.
Another command is "CreateSectionFromFile". After running this comand, A dialog box will open and you must open your text file and select alignment and other...
Your text file format for importing sectiong must be like this:
chainage83.695
-50.4085 14.0000
-38.5566 12.0000
-27.5584 25.0000
-11.5134 30.0000
0.0000 22.0831
8.8465 16.0000
22.8670 15.0000
40.2376 20.0000
48.6722 10.0000
"chainage"+Station and offset and elevation for below column.
Did @kh_night take into account this? :
Remember that GetSectionPoints( ) sometimes returns exrtra points or some misses.
So, you must check the sectionPoints collection if every point is really correct.
Hi
This dll can help you. After loading this with NETLOAD command, Type "Exportsec2xyzoffsta" and then select your section view and corresponding alignment and project level for centerline elevation. I revised and modified my code with your constraint.
I saw that post and I understood that we have a problem in section points.
How to "load tool" command visible in Auto CAD LT 2017. please advice me any guys...
Try this link http://esurveying.net/land-survey/cross-section-ls-road-design-software to find answer.
how can i drive below sample data from coordinates data x,y,z. please help in this regard
chainage83.695
-50.4085 14.0000
-38.5566 12.0000
-27.5584 25.0000
-11.5134 30.0000
0.0000 22.0831
8.8465 16.0000
22.8670 15.0000
40.2376 20.0000
48.6722 10.000
