I had a corrupted file that crashed every time it's opened. Now the drawing recovery manager has this message when i click on the folder to try and remove the temp files. Any ideas on how to remove the recovery folders so this doesn't keep happening?
Drawing Recovery Palette Error Message:
With Civil 3D not opened, can you not just go to the temporary folder and delete "all the files" in there? Using Windows Explorer. They probably need removing anyway.
Bill
I do that pretty consistantly. Isn't there a link folder somewhere under appdata that i can kill?
Andrew:
I am not sure we are talking about the same thing. I am not referring to the Windows TEMP directory. In Civil 3D, OPTIONS ->FILES tab there is a long list of file sources, etc. I am talking about "Temporary Drawing File Location". I believe it can be set for about anything including no folder at all.
Bill
I know what you're talking about. You're talking about deleting files from the "C:\Users\%username%\appdata\local\temp\" folder. I was just not aware if there was a folder under "C:\Users\%username%\AppData\Roaming\Autodesk\C3D 2013\enu\Recent" that might link to the Drawing Recovery Palette folders. I'll delete out my temp and see what happens from there and repost my results.
