Civil 3D Forum
Drawing Production
2 REPLIES 2
mehsan
282 Views, 2 Replies
Drawing Production
 For Plan Only
I have attached the images for the steps I am doing.
5. See Step-5.png (Here is the Problem why the Last View Frame is Overlapping)
For Plan and Profiles.
Using the same steps above when I comes to Plan and Profile (see Overlapping -1.png) than See Overlapping -2.png and at last Overlapping -3.png. if you see Overlapping-3.png you will observe that a match line is coming and the overlapping for every sheet is shown here I do not need overlapping and the match line too. Thanks
2 REPLIES 2
AlmasSuljevic
in reply to: mehsan
You may try to move overlapping view frames manually, by grip edits before you create your sheets.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
kulfi
in reply to: AlmasSuljevic
My question if i do not need Match line in Plan Profiles how can i do that and the overlapping.
Kulfi
Electronics Engineer
Pind Saudi Arabia
Rail Community
