For Plan Only
I have attached the images for the steps I am doing.
5. See Step-5.png (Here is the Problem why the Last View Frame is Overlapping)
For Plan and Profiles.
Using the same steps above when I comes to Plan and Profile (see Overlapping -1.png) than See Overlapping -2.png and at last Overlapping -3.png. if you see Overlapping-3.png you will observe that a match line is coming and the overlapping for every sheet is shown here I do not need overlapping and the match line too. Thanks
You may try to move overlapping view frames manually, by grip edits before you create your sheets.
My question if i do not need Match line in Plan Profiles how can i do that and the overlapping.
