Civil 3D Forum
drawing points using GPS
18 REPLIES 18
Message 1 of 19
julia5smith
2692 Views, 18 Replies
Hello,I am new to Civil 3d  how can I draw points in Civil 3d using GPS coordinates?
Is it any way to input the coordinates manually if i have only a few key points, and then superimpose my topography or other objects? or should I insert a data file to get the points first? How can I upload the data file from my GPS tool, and how to figure out in which format to insert it?
I  would like to draw with using the GPS coordinates itself, NOT the northing and easting( X,Y,) is it possible?
Thank you
Olga
Tags (2)
18 REPLIES 18
Message 2 of 19
tcorey
in reply to: julia5smith
When you say "GPS Coordinates" do you mean Latitude/Longitude?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 19
stewarteng
What I do is use the CREATEPOINTMANUAL command, and at the command line, the prompt says "please specify a location for the new point"; type 'LL which is the traanparent command for lat and long; then type in your lat and long.  Make sure you follow the correct format, including the N and W; type d after the degrees, ' after the minutes and " after the seconds (including decimal portion).
Works for me; I gave up trying to transfer garmin data to autocad; for a dozen or so points this way is just fine.
Brian
BStewart
Intel Corei7 975 3.33Ghz
24 GB Ram
Nvidea GeForce GTX 260
Windows 7 Pro 64 Bit
Civil 3D 2013 64 bit
Message 4 of 19
If you are inputing points manually and want to enter them by the northing and easting, use the transparent command 'NE.  Don't forget the apostrophe ' .
Todd Rogers
Message 5 of 19
Joe-Bouza
Data collector?
we have a hand held device that the GIS department can DL directly to GIS then export to cvs file for import int civil3d
Your Name
Your Name
Message 6 of 19
julia5smith
in reply to: tcorey
yes, I mean GPS coordinates which you can get from a GPS device, such as garmin, for example. I am not sure about professional devices for this purpose, and not sure in which format they store the data....
Message 7 of 19
julia5smith
in reply to: stewarteng
I will try this... But how to make sure I am using the right settings?
Thank you
Message 8 of 19
julia5smith
in reply to: Joe-Bouza
Could you please specify which device?
Message 9 of 19
Joe-Bouza
CArlson but I dont know the model
Your Name
Your Name
Message 10 of 19
julia5smith
thank you
Message 11 of 19
julia5smith
Brian (stewarteng), When i use your method, it seems like i do it incorrect, after i input my latitude and want to input my longitude, shoud I put coma between or what? I actually dont see my point if it was created, for example I do it this way:
command: CREATEPOINTMANUAL-ENTER,
LL-ENTER
 49° 9'13.79"N,122°56'54.06"W- ENTER
and then even if i zoom all i dont see my point.....what do I do wrong?
Thank you
Olga
Message 12 of 19
sboon
If you're trying to get coordinates from a handheld GPS into Civil 3d then there are tools available for that.  Most handheld units can download their data in GPX format.  These files can be converted to text files with either Lat & Lon, or coordinates.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
Message 13 of 19
antoniovinci
Dear Olga, I agree completely with Steve.
In XXI century you shall NOT enter anything by keyboard, but automatically by software: quicker and, above all, human error free.
Read carefully your GPS instructions, and export your data in .GPX format, then convert it to shapefile, e.g. here.
Message 14 of 19
stewarteng
Olga:
In a blank drawing, Type
Createpointmanual (enter)
Now the command line will prompt "Please specify a location for the new point:"
Type in     'LL (enter)         (apostropheLL- this is a so-called Transparent Command)
The command prompt will say "Enter Latitude <N0° 00' 00.00">:
Type in    N45d26'32.3" (enter)
The command prompt will say "Enter longitude <E0° 00' 00.00">:
Type in   W067d52'36.8"  (enter)
The command prompt will ask for a description
Type in description, hit (enter)
The command prompt will ask for an elevation
Type in elevation, hit (enter)
The command prompt will start again for the next point.  When you are done entering, escape out of the transparent command and out of the point creation command.  zoom extents and your points should appear.
Note that your ambient settings for latitiude and longitude could cause the prompts to have different looking formats.
FYI, I use a Garmin GPSMap 60CSX, and this method is only something I use to bring in a few points from a local survey traverse so that I can coordinate approximately with open source GIS mapping images.  I know that the data can be transferred directly, but for me it is not worth all of the steps required to make it work.
Hope this helps.
Brian
BStewart
24 GB Ram
Message 15 of 19
Easiest way to transfer data to and  from  consumer grade GPS units is with a program called Expert GPS (http://www.expertgps.com/ )
Program will create *.csv files that can be imported by C3D.
Remember that the coordinate accuracy from consumer grade GPS are only  1 - 10m HZ and 10 - 50m Vertical
Jim
Matrix3DSurveys
Message 16 of 19
...easier than the post #13 online converter?
It's free, and transforms a raw GPS file into shapefile in a couple of seconds, sir.
Message 17 of 19
Murph_Map
in reply to: antoniovinci
I used Expert GPS a few times and I was happy with the results. Asd a former Geocacher I liked keeping my finds in dwg format.
Murph
Supporting the troops daily.
Message 18 of 19
julia5smith
Thank you, I will try this.
Message 19 of 19
julia5smith
Thank you, tommorow I willl try this
Olga
Rail Community
