I am wondering if this is possible....I am a new user in C3D and i used to cut an existing ground profile and then I would copy that and take off the exaggeration, scale it, etc., then offset it 8 ft from the ground and draw in my pipe. In other words, I am drawing in the pipe how the contractor is supposed to put it in, drawing the fittings and everything, so it is 8 ft below grade. Is there a way in C3D to do this rather than doing it all manually?? Can I tell It I need a 24 inch pipe drawn in 8 feet below the existing ground and volla it does it? Thanks!
