Hi
I have a drawing the loads slowly and makes Civil3d become non responsive for i while.
It seems to stop with "finding interior borders" as the action in the lower left corner it has
some datashortcuts and xrefs on to a network drive.
Any suggestions on how to find what is the causing the slow down?
I will start by removing all the xrefs and datashortcuts and see if that helps.
I think I have read about slow load times with network drives recently but can not find the post again has anyone see it?
something related to xref's is causing the issue I removed all the xref's and drawing loads quick still with all the grading regenerating.
Thorught it maybe because the dwg came from microstation wblock out and refreshed with autcad still no joy.
"Finding Interior Borders" is a surface related operation. if you have monster surface it often hangs on it even if you do not edit it, very frustrating. The only work around is to reduce the amount of data in the surfaces working with.
If it helps unloading the xrefs, that seems strange to me Do you have surfaces in your xrefs ?
I have found errors every time a DWG of mine hangs on "Finding Interior Borders" when opening. Once 'Audited' and fixed, it opens without issue. As soon as I add breaklines (to a previously configured surface) I re-whack the DWG. Audit before closing.
This sort-of works. I still find that the drawing will still hang sometimes on open after auditing. I have to work with large surfaces regularly so this is a consistent issue.
