Active Contributor
mikerobe100
Message 1 of 6 (263 Views)
drawing lines using nodes
263 Views, 5 Replies
10-08-2013 05:59 AM
If I draw lines between nodes and then list the lines it gives me slope distances. how can I set it to draw 2D lines but still have 3D nodes? I want my points to display the correct elevation but when I draw lines connecting them I want the line to be 2D so when I list them I get the correct bearing and a horizontal distance.
Jeff_M
Message 2 of 6 (260 Views)
Re: drawing lines using nodes
10-08-2013 06:02 AM in reply to: mikerobe100
Set OSNAPZ = 1. This will allow you to snap to the nodes and ignore the Z value. Note that this setting is not saved and defaults to 0.
troma
Message 3 of 6 (234 Views)
10-08-2013 07:19 AM in reply to: mikerobe100
Another option: use polylines instead.  They will never draw in 3D.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Jeff_M
Message 4 of 6 (228 Views)
10-08-2013 07:30 AM in reply to: troma
However, they WILL draw at the elevation of the first point.
antoniovinci
Message 5 of 6 (212 Views)
10-08-2013 09:14 AM in reply to: mikerobe100
..or draw a 3Dpoly snapping on the nodes, then in a plan view _FLATTEN it.
Active Contributor
wetsnow13
Message 6 of 6 (199 Views)
10-08-2013 10:09 AM in reply to: mikerobe100
if they are nodes controled by a point style you can set the point style to flatten to elevation 0 and then use any line command with osnap for node.
