I'm working in Civil 3D 2012. I recently recieved a drawing from our surveyors for a small site design and I'm experience significant lag with simple tasks like panning, zooming, selecting objects, or making autocad the current window (while working with other applications). The program keeps freezing for a couple seconds at a time. I don't have any tool pallettes open. I've also tried to shut down everything except this drawing and get the same result.
The drawing is only 1,064 KB. Everytime it locks up, the CPU usage for that task jumps up to about 25 and isn't usable again until the CPU usage drops below 20. Working in other drawings, the CPU usage never goes above 20; it stays around 10-15 for most tasks.
I've tried auditing and found no errors. I've tried purging and found no unused anything that could be bogging it down. This drawing has no x-refs or images. The only 3d object is a surface with only 360 points.
We installed 2012 SP 3.0 on August 2. I know the guy that created the drawing recently got a new computer, but he said he didn't have any trouble with it and we're not seeing any problems with other drawings he's created.
I'm completely stumped. I don't know what else to check.
Solved by Ajilal.Vijayan. Go to Solution.
Also check the number of layers and layer filter of this drawing.
If you have too many layers, create a layer filter that displays minimum layers and keep the layer display to that filter.
I used to keep a layer filter that only shows the layer 0, and sometimes this works for me.
I think you hit it, with the layers.
I purged most of the unused styles; then purged all the layers and blocks that were used in those styles. Now it's working ok.
