Hi there.... Using the C3D plan production tools, I created a drawing file containing six layout tabs of Plan & Profiles. All works well when switching from one Layout tab to the next, but the drawing CRASHES when simply switching to Modelspace. In my baseplan file, where I have alignments and profiles, and only an existing grade surface to date, I do not have ANY issues with it. I created the layout sheets four or five times now using a Viewframe group, but nothing seems to work.
And yes, I've done the standard RECOVER, AUDIT, PURGE, and -PURGE
Solved by Jay_B. Go to Solution.
What Version & Service Pack?
Might be worth trying the suggestions in this Being Civil Post .
Here's the latest...
It seems to be working now. I set the sysvars as suggested in the link you provided (i.e WHIPTHREAD = 3 and LAYOUTREGENCTL = 2) and I was able to go to Modelspace without a crash.
However, NOTHING was visible.
I could select things with the QSELECT command and see the entitie's grips. I went back into the Layout tabs and could see all my Modelspace contents (so I know the layers weren't turned off).
After toggling back and forth between the Layout tabs and modelspace, everything is now visible, and no crashes. Even when switching the sysvars around, the drawing seems to be stable.
Thanks!
