Civil 3D Forum
Drawing a line from the center/ insertion point of a node
10 REPLIES 10
Message 1 of 11
1330 Views, 10 Replies
I have created some blocks and put them on layer 0 and set them up in Point Styles and description keys.When they are inserted into the dwg. attached to a point, I can not draw a line from the center or insertion point.  But I can draw a line using the POINT NUmber.  Any ideas?
Thxs.
David
10 REPLIES 10
Message 2 of 11
BrianHailey
Snap to the NODE.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 3 of 11
Why doesn't it find the insertion point/center of the symbol?  Do they lose these properties as nodes?
Thxs.
David
Message 4 of 11
Yes, when using a block within a point style, all AutoCAD properties such as center, quadrant, nearest, etc are lost because they are not important to a point. A point is an X Y and Z location, thus the other geometric properties of a "symbol" are irrelevant to a point location.
HTH
Message 5 of 11
Richard,
I tried snapping to the node and it worked on most of my blocks but not all.  Any ideas?
Thxs.
David
Message 6 of 11
Zoom your CAD file into one of your blocks that the NODE osnap does not work on and post the DWG. I can take a look at it.
Message 7 of 11
Thxs,.
Message 8 of 11
David
Wow - I am stumped.There is something definitely wrong with your MON point style. And I am also seeing some bad things in your CAD file. I inserted this DWG into one of my DWT's and all the same things return.
Perhaps exporting your points and bringing them back into a new DWG will help.
Sorry - perhaps you could reach out to Autodesk or your reseller for assistance. There are a few undocumented commands which might help.
Message 9 of 11
Thxs. for trying.
Message 10 of 11
Jeff_M
Edit the bm block.....erase the 2 wide polylines used for the fill areas and replace with either a solid hatch or redraw those polylines. Then the NODE Osnap will work.
Don't ask me why, because I have no idea why....
Jeff_M, also a frequent Swamper
Message 11 of 11
Thxs.  That worked great.
Rail Community
