I still having this issue: in Civil 3D 2013 spanish, after intalled SP1, draw order commands (right click > draw order) get a message " command not recognized", hope for a solution thanks.
_DRAWORDER is a relative function (you have to select the objects you wan to be over) and works fine (but is hard to use because objects are hidden when you want to use it, they are behind the object you want to send after).
But AI_DRAWORDER is automatic (same as right click "draw order" menu), and writing it down does not work either.
thanks
