Civil 3D Forum
Draping/overlaying Polyline onto the surface
3 REPLIES 3
15943 Views, 3 Replies
hi, I have a dtm of the ground and would like to drape a 2d polyline onto the surface elevation (converting it into 3dpline) so when I do a 3D orbit i can see the polyline move with the surface. InCad has a nice feature called "Drape onto Surface" I was wondering if civil 3D had that feature. Hope that's clear if not I'll try to explain again.
Best Regards,
Yuri
3 REPLIES 3
Hi Yuri,
You can't drape a polyline onto a surface, but you can convert it to a
feature line and pick up the elevations from the surface. Go to
Grading->Create Feature Lines to convert your 2D polyline into a feature
line, then go to Grading->Edit->Elevations From Surface to pick up the
surface elevations. Make sure you include the intermediate grade breaks.
Jon Rizzo
Langan Engineering and Environmental Services, Inc.
wrote in message news:5033071@discussion.autodesk.com...
Best Regards,
Yuri
Thank you sir. That works great.
Best Regards,
yuri
Excellent tip you have provided Jon.
Thanks a lot. Worksout wonderfully.
Rail Community
