Civil 3D Forum
drainage divide
1 REPLY 1
551 Views, 1 Reply
drainage divide
Does anyone know how to get the drainage divide lines from a layer with contour lines?
Should I use AutoCAD Map instead? How can I do it?
Thank you Edited by: eduardocmoreira@sapo.pt on Sep 24, 2009 10:18 AM
1 REPLY 1
Matt.Anderson
Eduardo -
You can use either the Watershed analysis in part of the surface properties. Or you can you the water drop together with the catchment areas tool
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Rail Community
