AutoCAD Civil 3D General Discussion
Distinguished Contributor
BMcAnney
Message 1 of 7 (310 Views)
Dragged state - flow arrows disappear
310 Views, 6 Replies
02-28-2008 07:26 AM
When I change pipe labels to a dragged state, the flow arrows disappear - is there a way to maintain them?
Brent McAnney
*Expert Elite*
Civil3DReminders.com
Message 2 of 7 (310 Views)
Re: Dragged state - flow arrows disappear
02-28-2008 11:25 AM in reply to: BMcAnney
Have you tried changein the dragged state from Stacked to As Composed?
Christopher
http://civil-3d.blogspot.com/
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
tyronebk
Message 3 of 7 (310 Views)
02-28-2008 12:11 PM in reply to: BMcAnney
Two options:
1) Change the dragged state to 'As Composed' (you probably will want to turn the leader visiblity to false)
2) Create two label styles: One with only the arrow which you won't drag, one with the text which you can drag around
Distinguished Contributor Mal
Mal
Message 4 of 7 (310 Views)
03-13-2008 11:11 AM in reply to: BMcAnney
Don't get me wrong I love the product.... but come on Autodesk developers.
Why does this have to be so difficult, and on something so simple as labels.
Already I have workarounds to label my start and end inverts to display along my pipe.
So I have
1. pipe size label, lenght and slope
2. start invert
3. end invert
and now I will have a style just so I can show a flow arrow, because if I show a flow arrow with any of the above three styles, in the drag state I will loose the flow arrow. Worse yet this 4th label style that is just to show the flow arrow will not display correctly if I have a pipe that curves, why, because the flow arrow goes from BC to EC and not along the curve.
There I vented..... feels better. Thanks for putting up with my ranting.
Member
Iaind867
Message 5 of 7 (100 Views)
04-10-2014 04:23 PM in reply to: Mal
AutoCad is designed to be difficult. Casuses cancer.
Member
Iaind867
Message 6 of 7 (93 Views)
04-10-2014 04:53 PM in reply to: Iaind867
Right now i'm battling the tail of the arrow. I would like it to disappear as it covers the entire length of the pipe, thus covering the pipe's line type. I'll probably just explode an arrow, delete the tail, copy and paste the head at each storm MH. Thanks Autocad.
Valued Mentor
david.zavislan
Message 7 of 7 (79 Views)
04-11-2014 10:06 AM in reply to: Iaind867
Create your own tailless arrow block and add it to your label style.   Anchor it to the flow direction arrow to control the direction it is pointing.  You may also need to rotate it 180 degrees, depending on the direction your block is pointing.  Finish the style by changing the flow direction arrow component visibility to False.
David Zavislan, P.E. | Wood Rodgers, Inc.
Post to the Community
New Post
Need installation help?
