Right now i'm battling the tail of the arrow. I would like it to disappear as it covers the entire length of the pipe, thus covering the pipe's line type. I'll probably just explode an arrow, delete the tail, copy and paste the head at each storm MH. Thanks Autocad.
Create your own tailless arrow block and add it to your label style. Anchor it to the flow direction arrow to control the direction it is pointing. You may also need to rotate it 180 degrees, depending on the direction your block is pointing. Finish the style by changing the flow direction arrow component visibility to False.
some of the recommended solutions here act as though more than one style can be applied to any pipe or structure how do i accomplish this?
You can place multiple labels on a pipe, one in a dragged state that displays the data and one in a not dragged state that displays the arrow.
Two labels
Joe Bouza
Right click the label style and toggle the leader tail off.
I know this is an old post but didn't see a reply.
