I'm new to Civil3D 2007. For a long time I've been wanting a simple way to creat point groups and add points to them. I found (much to my supprise, as I've been waiting for this since LDD3) that Civil3D finally makes this job easy. Create a new Point Group then Drag points to that group. (I wish you could just "Create New Group from selected points, but dragging is a big step forward")
Problem.
When I drag points to a Point Group, the Group needs to be updated. If I right click and "Update" I loose many of the points. Where if I right click and "Properties" then select the "Include" tab and hit "Apply", all the dragged points stay in the group. I think the problem is the list of points in the Include tab is malformed and when you click apply, the white space etc.. is removed from the list, where if you do the "Update" method only the list of points up to the first comma are included.
Example List: 207-213 , 318 , 340-345
In the above list, with the "Update" method only 207-213 are in the Group.
If I do the "Properties -> Include -> Apply" method, the list is reformatted to look like this: 207-213, 318, 340-345
Notice the leading space before each comma is removed. I think this extra space in the list is whats causing the problem.
Also, is there an easy way to remove points from a Group. If I select points (within a group) and hit delete the points are deleted from the drawing. Shouldn't there be an option to "Remove Points from Group"???
-Jeff
