Civil 3D Forum
Double-click edit (Text & Mtext)
6 REPLIES 6
rl_jackson
5114 Views, 6 Replies
We'll I'm not sure what happen here but, I can not for the life of me figure out why the double-click stopped working
PICKFIRST = 1
DOUBLECLICKEDIT=ON
and the Noun/Verb is checked
When I look at the CIVIL CUI, I do not have any double - clicks but the ACAD CUI does - this is load too right.
Anyway any help or suggestion would be great
C3D11
Rick Jackson
Survey CAD Technician VI
6 REPLIES 6
rl_jackson
in reply to: rl_jackson
OK now I have dragged all the double clicks form the acad cui to the civil cui and it looks as though I am getting an error. Yield sign with an exclamation.
Anyway, it seems like the double click is was possible alway working but it wants me to double click super fast.
Rick Jackson
Is the fast double click limited to only mtext objects?
If not perhaps you need to look at your windows double click spped.
Have you installed any addons for civil 3d lately?
Has there been any changes to your acad.lsp, acaddoc.lsp etc.?
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
It's limited to text, I for the life of me can not figure out why it is doing it. But it does seem to be limited to a single drawing.
Would you know its my first design job in about 1yr.
Rick Jackson
c.bergthold
Check the QAFLAGS variable it should be set to 0.
Cory
sbanister
in reply to: c.bergthold
I had the same problem, the above solved it.
Thanks cbess
doglips
in reply to: sbanister
I beleive for double click editing to function correctly Noun/Verb needs to be checked in the Selections tab of Options
Rail Community
