Civil 3D Forum
Double Click = Block Editor
5 REPLIES 5
bmossman
598 Views, 5 Replies
What do you have to set to in order double click & execute block editor in lieu of refedit???
5 REPLIES 5
riverdeer
in reply to: bmossman
I don't understand your question. All you should have to do is double click on a block or an xref.
bmossman
Currently when I double click on a block it executes the Refedit command. I went to a seminar recently & the instructor double clicked on a block & it brought up the Block Editor & had additional commands available to edit dynamic properties. Is there a setting that will execute the Block Editor in lieu of Refedit when double clicked?
By design, if you double-click on an XREF, you'll get refedit. Double-click
on a block, you get the block editor. Anything else is not standard
behavior.
James Wedding, P.E.
Technology Manager &
Associate
Jones & Boyd, Inc.
Dallas, TX
XP/2 on P4-3.4/1G
LDT 2006 & C3D2006
Not sure if this applies to you, but in 2006, the Block Editor edits Dynamic
Blocks. Refedit (also Edit Block in Place...) is for normal blocks. Double
clicking on a dynamic block brings up the Block Editor, while doing the same
for a normal block edits that block with Refedit.
Darron Agawa
bmossman
That explains it then....I'm in 2006 trying to open block editor for a block w/o dynamic attributes. Thanks for your help.
Rail Community
