Civil 3D Forum
does civil 3d have a best-fit coordinate transform option in survey?
3 REPLIES 3
daniellench
396 Views, 3 Replies
i may have asked this before,
my survey department has a DOS program from 1995 called Transform from GeoSoft.
it does not work well or at all in win 7 even with the XP mode virtual machine.
the program does a least square analysis with the ability to add or remove known points from the process, then outputs an adjusted file.
can the survey tab/database do this? if so how.
he is the only one left on XP32 and he is very particular
all the best and any information would help.
-dan
3 REPLIES 3
Sinc
in reply to: daniellench
The Survey Database can perform a least-squares adjustment on traverses... Then it can recalculate any sideshots taken from the control points, assuming you import your survey data via a FBK file or equivalent (e.g., something that transfers the instrument's observations to C3D, and not a reduced set of coordinates).
Not sure if that's what you mean...
-- Sinc
http://www.ejsurveying.com
http://www.quuxsoft.com
Sinc
daniellench
i think we tried that route once?!
i will revisit it.
anyone know of a good walkthrough?
while i'm proud of them for adopting civil 3d , their close mindedness is killing me. still doing asc files, no in field line work coding and a crew chief who is (sigh)
is anyone still using q-legal also or have you adjusted reports to output correctly Edited by: daniellench on Mar 9, 2010 1:40 PM
We still use Q-Legal. It does our deeds very well, very fast.
John Mayo, PE
Core i7 920 6GB DDR3
Radeon 4870HD 1 GB
Vista64
Rail Community
