I been docking tools bars, no problems, However I would like to change the order on the rght side.
it seem the only way to change the order is remove all the dock tool bars then add them in the order I want them.
You can do this with the other items, such as the sheet layout, and ribbon.
Is there a way to drag them to a diiferent order/place.
Tanks
I'm having the same issue and wanted to bump this thread in the hope that someone more knowledgable than myself might chime in with a solution.
Brian
Brian,
You can change the order of some things in the CUI. Can you post a screen grab of what you'd like to re-order?
Dave
Dave Stoll
Las Vegas, Nevada
FYI:
For my work around, say I want to change the order on the left side, I would move each one to the Right side then back to the left in the order i want them.
To keep the order, I would then create/save the workspace. so if for some reason you close out the tool bars, just change the workspace to ?? and them back.
You could also add the switch to w/ "???" to your startup icon. ??? is the workspace name. This way when you start autocad you load the workspace.
NOTE: Make sure, under workspace setting, you have "Do not sace changes to workspace"
Hope this help.
