My company is getting ready to upgrade from v2013 to v2015, and I was wondering the the known issue regarding x-refing files with both pipe networks and surfaces still exist in v2015?
Thanks.
Solved by ToddRogers-WPM. Go to Solution.
If you're referring to the pipes being DREF'd in, when synchronized, they revert back to their default settings, then no it was not fixed. However, service pack 1 fixes that issue
@Anonymous wrote:If you're referring to the pipes being DREF'd in, when synchronized, they revert back to their default settings, then no it was not fixed. However, service pack 1 fixes that issue
That's the issue to which I was referring. Thanks.
