I have a table of Wind Turbine coordinates but I don't want to show the point number - is this possible dynamically??
The only alternatives I've come up with are to use a wipeout but then the heading is off centre or to just explode and manipulate as CAD entities, neither of which are ideal
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by Jeff_M. Go to Solution.
There is a workaround... you can actually go into edit your table style and copy/paste a different column value into the first column in lieu of the point number. Strange to have to do this to bypass, but I believe they didn't wan't you to ditch your point number:)
Thanks for the replies guys - that did the trick admirably
...although you can't help feeling it would be easier to have a radio button/tick box to achieve this
