Civil 3D Forum
Divide the strippingpavement
3 REPLIES 3
FranciscoGTO
249 Views, 3 Replies
I have a question which I have not found solution.
In a project, asks to separate (in section view) the area of " stripping”
in fill situations and in cutting situations.
The áreas in the section view should appear as different areas (something like stripping in Fill= 12sqm and stripping in cut= 3sqm… for each section view)
Civil 3D can do this ? Or I have to do it manually ?
If it is possible, how should I do it?
I'm using the "strippingpavement" subasembly but it only let me get one area and not separate as I need it.
Thank you in advance.
3 REPLIES 3
tcorey
in reply to: FranciscoGTO
If you create a surface from the top of stripping and a surface for datum of stripping, you can use Compute Materials to set conditions for what is cut stripping and what is fill stripping. See my blog post which should give you the workflow you need:
https://www.blogger.com/blogger.g?blogID=1955172010377889732#editor/target=post;postID=3361763303125...
It's not specific to your task, but your workflow will be similar.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
FranciscoGTO
in reply to: tcorey
Thanks for the answer.
I think I have the idea.
The link is broken. Do you think you can uploaded again?
I want to share this video:
https://www.youtube.com/watch?v=tDvU6PWuX-8
Simon Noyola Rivero
Application Engineer
Down to Earth Technologies, Inc.
Autodesk Authorized Consultant
Subject Matter Expert Civil&Map
Civil 3D Country kit  development
para: Mexico, Central America, Caribbean & Venezuela
https://www.youtube.com/user/snoyolar
Rail Community
