Civil 3D Forum
Divide parcel by sliding bearing
3 REPLIES 3
mcloughlin
566 Views, 3 Replies
I append an image of a long thin parcel 0.704 acre in area.
I need to divide out a portion of this parcel 0.28 acre in area at the northwesterly (upper left) end, with the new boundary line to be parallel with the northwesterly boundary line N 33d 12' 28" E.
I go to Parcel Creation Tools, pick "slide line" as the tool, pick frontage as instructed, etc., and "NO SOLUTION FOUND."
Pick a different frontage; "NO SOLUTION FOUND."
Futz with settings in Parcel Creation Tools; "NO SOLUTION FOUND."
This can't be TOO complicated, can it?  What am I doing wrong?
3 REPLIES 3
Joe-Bouza
in reply to: mcloughlin
you probably need to reset the parcel tools to accomodate the smaller area and frontage
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Pointdump
McL,
Like Joe said. Also check to make sure Automatic Mode is turned off.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
mathewkol
And set the setbacks to "No" and any other settings you don't want used to something really small.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
